Better Brackets For 12V 10W RGB Floods
Grandpa Elf
In my own display I use some of the 12V 10W pixel I/O flood lights that come from Ray Wu, etc (pictured below).
They work well for smaller areas, up-lighting smaller trees, etc, but the U brackets are very thin and buckle easily.
I want to look into how much stainless steel U brackets would cost to get made.
The steel bolts (M6 x 10mm) also rust within a season or two, but they can be bought locally quite easily.
Is anyone else interested in better brackets for their lights, or have you already seen a source of SS ones ?
As an aside, I opened one up and the PCB says 12V - 24V and I've been running them on 24V with no issues.
Iain
Darwin
Interesting on the 24V supply-I do want to get some more for my thick foliage fence so this would help…
I had to make sure mine were not dimmed like the rest of my display and then the brightness was ok.
I meant to reply to this bit! I’d be interested in some sort of ground stake for them…
Katekate
Portland, Vic
I bent my own up out of aluminium flat bar. I added spacers to keep the bracket clear of the housing so it can tilt downwards.
This pic was the prototype, I made better spacers out of Delrin.
Grandpa Elf
I got aluminium stakes for mine from AliExpress.
Search for garden light stake.
