4 wire cluster lights
Juddge
Hi , lights with a controller midway down the lead to the lights
It’s cluster led
Has 4 wires from the controller - is 34vdc
I have the dmx36mk2
Will this replace the controller for these lights ?
Notenoughlights
400,000+ twinkly lights
Christchurch, New Zealand
At a best guess, to the controller has 2 wires from a plug pack and then the light set from the controller has a common + and 3 negative lines, so essentially you could just switch each of those lines on/off (or connect all 3 negative lines together) and switch the whole lot at once.
Juddge
so the dmx36mk2 is designed for these style lights - excellent - ill cut off a controller and wire to the dmx and experiment
