So as you know advatek are 4 pin. I purchased their connector wires which I'll solder to later on. For now it's crude. I used their manual to determine which wire was which and had it working in the test mode on the advatek assistant, just not in xlights.
How do I connect 3 pin pigtails to the advatek system?
It’s still the same controller, they’ve just put it in a fancy box and configured it for you. I would assume it’s not set to expanded mode, but assumptions in pixel lights configuration is a dangerous game to play. At least you have the bonus of being able to play with it later when you have more confidence in yourself.This is the Advatek plug n play system. Whilst it may be easier for beginners, now I can see why people buy controllers and power supplies separately & make their own. Should have my Falcon controller within a couple of weeks, then I'll have better control. Spending so much $ at the moment and I can see it will only continue.
Thanks to everyone for your replies & assistance with this thread!
That's correct. Not in expanded mode but I can see where to enable it. Pretty keen now as I'm learning more & moreIt’s still the same controller, they’ve just put it in a fancy box and configured it for you. I would assume it’s not set to expanded mode, but assumptions in pixel lights configuration is a dangerous game to play. At least you have the bonus of being able to play with it later when you have more confidence in yourself.
Hi I have a plug and play and finding it impossible to buy nodes with a 4 pin pigtail a well. Can you let me know if you were able to buy an adapter or only outcome is rewiring . That is not an option for me sadly.This is the Advatek plug n play system. Whilst it may be easier for beginners, now I can see why people buy controllers and power supplies separately & make their own. Should have my Falcon controller within a couple of weeks, then I'll have better control. Spending so much $ at the moment and I can see it will only continue.
Hi Julie, I bought the advatek system as this is my first year using pixels. Advatek sell pigtail kits to which you can solder 3 wires to your pixels. I'm doing that for this year. I also just purchased a Falcon controller and will be using XConnect pigtails on my new pixel strings.Hi I have a plug and play and finding it impossible to buy nodes with a 4 pin pigtail a well. Can you let me know if you were able to buy an adapter or only outcome is rewiring . That is not an option for me sadly.
Hi CDIHi Julie, I bought the advatek system as this is my first year using pixels. Advatek sell pigtail kits to which you can solder 3 wires to your pixels. I'm doing that for this year. I also just purchased a Falcon controller and will be using XConnect pigtails on my new pixel strings.
Is there a reason you can't rewire?
I have the same problem but worked around it by using the "Bulk Controller Upload" item in the Tools menu. Works perfectly for the 2 Pixlite Mk2s I have just bought.Hi All,
So first year, first time. Got a Pixlite 16mk2 P&P and lights so far with a falcon F16v3 on it's way as well. Created a sequence and when I got to Upload out put I get "Ädvatek Output Upload Failed. Unable to connect" Nothing fancy just me stuffing around learning XLights
I'm sure it's something simple but beyond me at the moment. I've googled searched & read everything I can. I have a green IP light, my IP matches obviously. I do think it's to do with my Advanced control settings in the advatek assistant. But I can't see what. Everything here talks about channel ends etc. I have it set as 150 pixels on the string, so 450 channels.
Please help a newb ?
