this is focused on xx to 5V at the moment.
It is a lot easier to deal with a higher voltage and then convert down to 5v at the point of demand ie your string of pixels.
I ordered these little units last month and they arrived today
That is a xx to 5v at 5A buck convertor!!!!! it's quite tiny and the general chat consensus was maybe an amp or two before fire
Time to test, one bench power supply some 32x020 cable on each side and an electronic load.
Sorry no thermal camera, finger tips for temp
At 12v input and 4.9v out few about 10 minutes i had no issue holding it
So set the load to 4A and started to wind the input voltage up. At this point it did start to get hot... the IR gun got a peak reading around 70c
Next was the low volt limit - surprisingly this worked all the way down to 5.8v and only at 5.7 did output voltage drop
Set it back to 12v input and 5A current
At this point it's had a solid 30 minutes @5A and i can still hold it for a bit, it's hot but not burning
Conclusion:
Excellent even derated to 4A they are more than enough for a string of pixels
These little units cost me ....... around $2.00 each!!!!
They will make great point of use conversion units. will pot one in epoxy though and retest
They show over 1/4 million in stock
Cheers and I hope this helps someone, i'll do some more testing and prepare a usage guide for them.
Conclusion:
4.95AU $ 40% OFF|5A DC-DC Mini560 Step-Down Stabilized Voltage Supply Module Output 3.3V 5V 9V 12V DC DC Buck Converter Regulator Mini 560
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
